Can you advise me of the IP address needed for the Licence, info needed for my IT in order to pass new fire walls. Connection client cannot connect due to new fire wall, My It need info in order to create an exception.
Many Thanks, Gary.
On 18 Oct 2019, at 15:30, Shane Regan <bounce-03FBF8A3-8D24-488A-B7A0-F4C098648C95@communities.bentley.com> wrote:
<Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4TR4SXJDV8NG-jpg_2D00_70x70x2-jpg> Shane Regan Hi Stuart, Is this in relation to running Hevacomp projects? If so please note that you can continue to use Hevacomp without logging onto Connection Client, as Hevacomp is not Connect Edition software. As long as Hevacomp itself is installed locally you should be able to open Hevacomp and navigate to the Cloud location as with a normal project. Are you getting any errors running Hevacomp itself, or is it just the above Connection Client warning? View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
Hi Stuart,
View online
Hevacomp is not supported for Cloud based installations so you will just need to install locally on each machine. You will not need to do anything different in relation to licensing - just enter the activation key as per normal.
There should be no issue accessing projects that are saved on the cloud based drives as long as they are mapped and full permissions are present.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
