we carry out a lot of installations which requires Point of Use water heaters (10/15L unvented systems), how to i include this within the CWS designs please.
Hi Rob,
I would suggest adding them as Special Outlets which allow you to define all the parameters you would need including Description, Flow Rate and Loading Units.
Best RegardsSteve
Steve Brown | Bentley Systems
