Hi
Understood the below links gives K-value for some of the fitting however, it doesn't show the assumed value for different default bends and tees . Please could you be able to post the k vale for the default connection fittings. i want to verify the pressure loss is correct and is inline with CIBSE guide C.
https://communities.bentley.com/products/building/performance/w/building_performance__wiki/17605/pipe-and-duct-fittings-k-values
Many Thanks
GL
Hi Shane,
The key issue is if software cannot tell the K values breakdown, we wouldn't be able to adjust the design to reduce pressure drop to where required.
I encountered design software that gives the C-value (similar to K factor) however they are not CIBSE or DW144.
Sounds like we probably have to go back to hand calculations or source other tools, until Hevacomp updates the software.
Thanks for your response.
Carmen
