CWS PD/METER
HI
IS IT POSSIBLE TO DEFINE CWS SYSTEM WITH MAX  250PD/METER. UNDERSTOOD THERE IS A WAY TO DEFINE MAX VELOCITY, HOWEVER AS THE VELOCITY AND PIPE INCRIMINATE IS NON-LINEAR THE  SOFTWARE UNDER SIZES THE PIPE RESULTING IN HIGH PD PER METER.  PLEASE ADVICE IF THERE IS ALTERNATIVE WAY TO LIMIT PD/METER TO 250PA.
REGARDS
GL
