I am trying to model a pitched roof which has a number of flat roof dormers built into the pitch of the roof.
When I go to model the vertical parts of the dormer, the vertical parts of the roof form a rectangle shape which appears to form a wall within the room below the roof.
Is there a way of modelling the vertical parts of the dormer roof so that they form a triangle shape which follows the pitch of the roof?
Andrew
Hi Andrew,
Unfortunately not - rectangular shaped windows can only be drawn. I would advise entering numerous small rectangular windows to the same total area in this space, or alternatively you could use Room Data mode to manually enter the window area figures.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane,
Thanks for getting back to me.
My issue isn't with placing windows in the vertical faces of the dormer.
See the screen shot below. I am trying to get the vertical section to follow the line of the roof of the pitched roof, rather than dropping below into the room. Is that possible?
Thanks Andrew
Apologies, I misread your question. Such vertical sections can be tricky. I can take a look if you could please forward the zipped project file? Please upload to:
https://bentley.sharefile.com/r-rc2180c8c53345849
To clarify, as I understand it you wish to avoid the walls in the rooms below from rising up to meet the roof at the dormer, as in image below:
and in their place you only wish to only have vertical roof sections, long the lines of:
Do I understand correctly?
To add to the above, I see the issue you refer to in relation to the roof sections themselves, ie:
Usually the 'Fill vertical section' option when tracing roofs would be appropriate in such cases - I will try to come up with a workflow to get this working and will let you know.
