I am trying to model a pitched roof which has a number of flat roof dormers built into the pitch of the roof.
When I go to model the vertical parts of the dormer, the vertical parts of the roof form a rectangle shape which appears to form a wall within the room below the roof.
Is there a way of modelling the vertical parts of the dormer roof so that they form a triangle shape which follows the pitch of the roof?
Andrew
Hi Andrew,
Great, thanks for letting me know. Dormers and attic rooms can be tricky at times, so if you have similar difficulties with future projects you can always convert to Room Data mode if needed and manually enter the surface areas (note however you won't be able to use CAD thereafter).
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
