Hi. I am using Netsys to design the cold water system for an industrial site. When I run the calculation it does not achieve the sum of the outlets. I've narrowed this down to two places where the components when added mathematically are greater than the flow rate produced by Netsys. The screenshot below is one of the problem areas. I would have expected the flow rate on the left to be:-
8.151 + 0.269 = 8.42 l/s
(Netsys figure is 8.19)
Stewart Bullock
Hi Stewart,
Assuming you used standard outlet types the software is following the BS standards to take account of diversity in the system using Loading Units. You should refer to this Wiki for more information.
Best Regards
Steve
Steve Brown | Bentley Systems
Answer Verified By: Stewart Bulllock
Hi Steve
Thanks for the reply. The Wiki explained it perfectly.
Stewart
