How do you extend the external walls of a building to the underside of a roof that you have created but at the same time keep the internal partitions of the respective rooms so that they only extend to the underside of the false ceiling when using the design database tools in HevaComp?
Hi Rachel, yes in this case I would usually suggest ticking both options prior to setting up the roof.
Detailed guidance on setting up your roof can be found in the manuals as below. (This can be accessed as detailed here).
For the floors below, please use the Set Up Intermediate floors/ceilings option, (which also has a similar false ceiling option) - further guidance can be found below:
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
