HELP WITH LOAD CALCULATIONS DATA AND TRANSFERRING IT INTO TOTAL BUILDING DESIGN
I have constructed my hevacomp model in the design database using the load calculation tab along with sizing all my mechanical pipe and duct systems using the pipe and duct sizer netsys tab.
I am wondering if it is possible to transfer all this data into the SYSTEM BUILDER "TOTAL BUILDING DESIGN " tab without having to re model and size all my work that I have already done.
any help on this matter is most welcomed
Seamus Murphy , BEng , BEng Ord
  • Good afternoon Shane
    I hope you are keeping well  during this difficult time.
    I am wondering if I maybe able to get your assistance.
    I am having great difficulty in adding in floor connectors for my cold water services installation using Netsys.
    Each floor is 3m in height with the pipe work on each floor level @ 2.8m , bar the roof level where it is @ 0.45 m off ground
    Can you please provide some assistance on how to install the floor connectors to connect the rising main to each floor ???
    Any help on this matter is greatly appreciated .
    I can also send on the netsys pipe files if needed.
    NETSYS CWS INFORMATION
    floor -1 - plant cws system marker located on this floor
    FFL IS @ 0M
    cws pipe work level 2.8m
    Floor 0
    FFL IS @ 3M
    cws pipe work @ 2.8m
    Floor 1
    FFL IS @ 6M
    cws pipe work at 2.8m
    Floor 2 - GREEN ROOF.
    FFL IS @ 9M
    cws feeding 3 roof taps @ 0.45m
     Kind Regards
    Seamus Murphy
    Junior Mechanical Engineer
    Homan O'Brien • Consulting Engineers
    89 Booterstown Avenue Blackrock, Co. Dublin, A94 P2C2, Ireland.
    Tel: +353 (01) 2056300 Fax: +353 (01) 2056301
    Email:  seamus.muprhy@homanobrien.ie   Web:  www.homanobrien.ie
    140012015 Small45001 Small
     P  please consider the Environment before printing this E-Mail
    This E-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
    Any views or opinions presented are solely those of the author, and do not necessarily represent those of Homan O'Brien. If you have received this email in error please notify the sender.
    Although Homan O'Brien scans E-mail and attachments for viruses, it does not guarantee that either is virus-free and accepts no liability for any damage sustained as a result of viruses.
    Homan O’Brien & Co. Limited trading as Homan O’Brien Associates. Directors: Brian Homan, Simon O’Brien, Gerard Keating, James Reilly. Registered in Ireland No: 158319. Registered Office: 89 Booterstown Ave, Blackrock, Co. Dublin.
  • Hi Seamus,
    I'm doing well all things considered, many thanks, hope you are too. It's usually a case of drawing vertical risers up to the height of the floor above, and then entering the correct values into the Floor Change Connector menu. I'm not sure if you have seen our step by step guide on this? This can be found here.
    So, for floor -1, you would rise from 2.8m to 3m, then place the connector. If you need any more specific instructions by all means let me know.
    Shane Regan | Principle Building Performance Support Engineer
Reply Children
