I am using V8i SS1 SP10 and an getting a Run time 9 error when adding a pipe to a floor connector and rising the pipe vertically. Deleting the associated duct on the floor below and redrawing results in the same error. Also group deleting and redrawing does not help. Any help appreciated
David
I think I would need to see the project. Can you upload it to this secure link and reply with details of which floor and area so I can take a look.
RegardsSteve
Steve Brown | Bentley Systems
Hi David,
I've been unable to replicate the Error 9 but having looked at your floor levels and the system in isometric view I think it may be related to the values you are using to create your floor change connectors. None of your floor heights are 3.5m so that isn't an appropriate value to use. When defining floor change connectors you should consider the height of the floor you are connecting to. We have a useful WIKI on how to correctly draw floor changes to ensure you get all your duct lengths correct as the calculations only consider duct that is actually drawn. No duct length is implied from floor change connector heights.
The image below is from your project and as you can see there are gaps between floors where risers should be.
Below is a section I created to show the finished floor levels (FFL) and floor to floor heights you have in your project. This will help when adding floor change connectors in line with the WIKI I mentioned above.
Try completely deleting and redrawing the floor change connectors for the sections you are struggling with and see if this resolves the issue which I think may be due to using incorrect heights.
Best RegardsSteve
