I closed a Hevacomp file last week and when I came to work on it today the project folder doesn't appear in the list. When I asked a colleague to look for it they were able to open and view all aspects of the file.
I am now getting this message when I try to open the file from the project folder but am reluctant to carry out the request in case I lose the project totally.
Hi Graham,
I note this is on a server so it may have been temporarily offline, or perhaps your Windows permissions changed. It would be a good idea to request full permissions from your IT as detailed here.
Also I'm not sure if you are using Project explorer or Windows/path file (below), but I would suggest using Windows/path file.
It appears you are trying to open a security copy of the project - if you instead select the Landlords folder does the project open for you?
Could you also please let me know the version number on your Hevacomp main screen?
Note that if you are worried about losing data please back up the project folder beforehand - ie simply navigate to the project location on your server and make a copy of the Hevacomp project folder.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
