CIBSE Gain Queries
I have turned off infiltration, ventilation, occupants and casual gains from my model to test the solar load portion only. However I still see loads attributed with "Convective" and "Latent" (albeit small).
Should these loads exist in my calculation, if the below suggests "Convective" is from infiltration or ventilation air & "Latent" is from occupants, casual and infiltration only?
Also, can I tabulate individual gains for each room? The "Results" tab shows total sensible and total latent loads only, whereas the "Graph" views shows the individual loads, but not that can be read off accurately.
The description below taken from an older thread;
  • Solar Load
    This is the direct and diffuse solar loads through glazed components (windows\rooflights)
  • Fabric Load
    This is the sensible load from fabric components (walls, floors, roofs etc)
  • Convective Load
    This is the sensible load from infiltration. It also includes any fresh air or conditioned air introduced locally to the room
  • Latent Load
    This is the latent load from people, equipment and infiltration.
  • Casual Load
    This is the sensible load from people, lighting  and equipment.
Graeme
Parents Reply Children
