When using Hevacomp Connect I get 'Failed to open graphics server' error message when I click on discrimination report.
Hi James, this seems to be an issue caused by Windows components rather than Hevacomp itself so it is tricky for me to give a certain solution to this, however the guidance at the following article may be of assistance:https://support.microfocus.com/kb/doc.php?id=7770803Could you please check that only one copy of each file exists?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
I can confrim only one copy of each file exists.
