HEVACOMP Heat Loss Result
Hi Good morning,
For the HEVACOMP Heat Loss Calculation, is there a way to know the required supply air flow based on the calculated total heat loss from the result? I'm looking at something similar with the CIBSE gain calculation where the result shows the air flow.
Thanks!
