I have an active project which has encountered a "run-time error 62 input past end of file" error.
When I load up the project all of the data seems to have been lost, is there a way to recover the project?
Good to hear Thelma! Thanks for the feedback.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
I keep having this issue with one of my models.
It is not letting me go into weather data to input my weather files correctly. My global changes and fabric data work fine, it just seems to be the weather data that gives the error message as shown below.
Would you be able to provide a solution please.
Many Thanks.
Hi Aakil,
Please create a new forum post should you have any new issues - replying to old ones can often be missed. Also the above issue is in relation to materials rather than weather, so while the error is similar, it is largely irrelevant.
I will respond to your new post as soon as you raise it.
Many Thanks,
Shane
