Does one of the cable types already included in the standard drop down menu match LSX cable?
Steve
Hi Steve,
This range is not available in the software unfortunately. If this is required, you would need to manually enter the required data using: 18th Edition > Cable Data > Add new Cable file.ás below.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
