Does anyone have a guide for modelling dormer windows on to a pitched roof? I can't for the life of me get themto work.
Thanks.
This can usually be achieved by adding vertical roof sections. The thread here may be of some use to you with this - in particular: "you will need to be very careful that the outline of the roof matches that of the rooms below".
and:
"Dormers and attic rooms can be tricky at times, so if you have similar difficulties with future projects you can always convert to Room Data mode if needed and manually enter the surface areas"
If you require any more specific advice on this I would most likely need to see the project in question, so please let me know how you get on.
Shane Regan | Principle Building Performance Support Engineer
