Hi Jovannie, the user defined fitting will be in addition to the bend, it will not override it. Unfortunately there is no way of manually editing the K-values in the software for the automatic bends tees and fittings.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
Thanks for this.
I just want to clarify regarding this specific point.
Is there no other way for us to use the data (using Hevacomp Netsys software) for K values as described in CIBSE Guide C 2007 and not in CIBSE Guide C 2001?
Hi Jovannie,
No problem at all. Unfortunately not, there is no way of manually altering the K values - the only way to work around this would be to modify the bend/tee type by using Fix Bend/Tee option as below:
The K value details used in the software listed here may also be of some assistance to you.
