I have a run time error 11 appearing when sizing heating pipework in netsys. I had previously sized the system with no issue, however made some amendments and when re-running it the error has appeared.
Could anyone assist as I currently can't access the results of the system sizing for an urgent project.
Phil
So I created a new heating pipework project to try and get around this issue, however when i come to size the system I have the same error again.
I have tried sizing other systems and CWS etc. work ok, it is just the heating system sizing which is reporting this issue.
Hi Philip,
Apologies for the delayed response. This error means that there is invalid data within the system. This could be an open ended pipe, or emitters on top of each other, or similar.
I can check this for you if you could please upload the project to this link.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
I have uploaded to the link you sent.
Thanks for you help
Thanks Philip, I am inspecting it now.
Did you have any luck with the file?
