I have a run time error 11 appearing when sizing heating pipework in netsys. I had previously sized the system with no issue, however made some amendments and when re-running it the error has appeared.
Could anyone assist as I currently can't access the results of the system sizing for an urgent project.
Phil
Hi Phil,
I suspect that invalid data in floor change connectors is the cause of the error, however there are so many that it is proving quite difficult to pinpoint the culprit. I will get back to you later on today.
Shane Regan | Principle Building Performance Support Engineer
Thanks Shane,
When originally creating the project, I had a closed loop pipework error associated with the riser adjacent M32 on the 3rd floor and running down the building. I deleted and re-drew that riser, perhaps that may be the culprit.
Cheers,
Hi Philip,
Thanks for the tip. I found that the error is actually due to the floor change connector between Floor -1 and Floor 0.
Please go to Floor -1, and use Pipes > Group delete, to delete the connecter and associated riser.
Then, go to Floor 0 and do the same where the same connector appears on that floor.
You should then re-enter the connector as shown here.
Or if you need I can send over the working model, just let me know.
Hi Shane,
Thanks for that, i've tried deleting the sections suggeted but am having the same issue. Could you send over the working model please?
You should have received a private message with a link for the above. Note the bottom two floors will need to be connected back up. Hope that helps.
