Is there a way to create different references to indicate various types of emitters located on the same floor, that will then display in the schedule output.
Hi Christopher,
Yes, if you select Emitters > Emitter ref defaults you can find an option to specify a different emitter prefix for each floor:
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Christopher, apologies! I misread your initial question. Unfortunately not, the prefixes must be the same for all emitters on each floor.
