Staad Output file of a concrete beam
  In the Staad Output file of a concrete beam, I am getting the following  results: I do not understand the one that is highlighted. Explain me pl.
SECTION      0.0 mm      328.8 mm      657.5 mm      986.2 mm     1315.0 mm
    TOP       3-10í         3-10í         3-10í         3-10í         3-10í
   REINF.   1 layer(s)    1 layer(s)    1 layer(s)    1 layer(s)    1 layer(s)
   BOTTOM     3-10í         3-10í         3-10í         3-10í         3-10í
   SHEAR   2 legged  8í  2 legged  8í  2 legged  8í  2 legged  8í  2 legged  8í
   REINF.  @ 110 mm c/c  @ 110 mm c/c  @ 110 mm c/c  @ 110 mm c/c  @ 110 mm c/c
    SHEAR DESIGN RESULTS AT DISTANCE d (EFFECTIVE DEPTH) FROM FACE OF THE SUPPORT
    SHEAR DESIGN RESULTS AT   315.0 mm AWAY FROM END SUPPORT
     VY =     0.00 MX =    -1.62 LD=   17
     Provide 2 Legged  8í  @ 110 mm c/c
Parents Reply Children
