Dear Hevacomp
The latest patch has been released and no xml can be generated without this patch. Can you please advise how to install this new patch
Rob Diamond
Senior Sustainability Associate
01206 646036
Hi Robert,
The timing of this SBEM update is most unfortunate as it has directly coincided with the transition of Hevacomp to OpenBuildings.
The core issue compounding this is that there is always a grace window for such updates however this has not been provided by BRE, on this occasion only.
As you should have seen in the email that was sent out (image of which below) there are no further updates possible for Hevacomp, so we are working on a route for users to obtain their PartL outputs and XMLs from OpenBuildings, via the Hevacomp Import option.
We are aware of the urgency of this matter to our users and are doing everything possible to expedite this.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane,
What is the latest with this? we need to run an L2 calculation to generate and lodge an EPC using the latest version 5.6b but don't appear to be able to do this through Hevacomp or OpenBuildings Energy Simulator!
I have a client who is expecting this to be done this week.
Tony
Hi Tony,
Yes, a priority build has been completed for this in OpenBuildings and we are awaiting its listing on the approved software list, at which time I will be announcing details online.
I will log a Service Request to send you an email including this shortly.
Shane
