I want to model a chilled water ring main so that an emitter can be fed from 2 directions for redundancy. Can hevacomp Netsys do this?
Hi Vaughan,
An emitter can only have one connection point to the pipework so what you describe would not seem directly possible. In addition, this would also result in a closed loop, which would cause the calculation to fail. I can only suggest perhaps modelling using two emitters of equivalent output, if suitable.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thanks Shane
No problem at all, please let us know if you need anything else.
