When importing Hevacomp DDB model to Openbuildings I get following error massages:
1) System.NullReferanceException: Object reference not set to an instance of an object at Bentley.Building.Se.....
2) OpenBuildings Designer has detected a problem and logged it to [file path]
Use Abort to exit OpenBuildings Designer (recommended)
Use Retry to continue OpenBuildings Designer
Use Ignore to continue using OpenBuildings Designer, and suppress future porblem notifiactions
After these notifications i get back to OpenBuildings Designer but no model has been imported.
I can provide screenshots of the above error messages if this would be helpful.
Many Thanks,
Adam
Hi Adam,
Many thanks for letting us know, I can take a look at this for you.
(I also understand that you requested to have your fulfilment contacts changed - I have added you to our system as a user and our licensing team will assign the required permissions).
I will contact you via Service Request shortly to obtain the above project from you.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
I had this problem today.
Try saving the .DGN file in a different location then try importing again,
For me I had to save the .DGN model I was importing to, to my desktop first then import the model.
Hope this helps
For any other users coming across this issue; we found that this was due to a simple text issue, for rooms with the Room Type of: Circulation(private).
Our developers have addressed this and will be resolved in the next OpenBuildings release.
For now, to resolve, please simply change the room type from Circulation(private) to the nearest equivalent, eg:
The project should then import fine.
