Hi, is there a way to add a certain pipe type to the database. I am looking to add PE pipe SDR 17.6 with particular ODU/IDU and surface roughness. Sizes range up to 315mm.
Stuart
Hi Stuart, adding custom pipe ranges is not possible unfortunately.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
