Is Hevacomp integrated with projectwise? Is their a routemap to using Hevacomp with projectwise at all?
Hello, Hevacomp does not have any in built integration with ProjectWise so such a setup would not be officially supported. For ProjectWise integration you would instead need to use OpenBuildings (info here). OpenBuildings Energy Simulator now contains all the capabilities of Hevacomp Design Database, and Simulator - further details can be found here.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
