Good afternoon,
Please see the attached cleaned up DXF file, together with the corresponding error message.
When I attempt to import this DXF into Hevacomp to do some pipe sizing calculations, the software flags up a run time '13 error.
Does anyone know what the issue could be and how to resolve it?
Your assistance would be greatly appreciated.
Thanks.
Alex Rowe
RABY GARDENS AS COMPLETED UPDATE 11-03-2019-Cleaned Up.dxfRABY GARDENS AS COMPLETED UPDATE 11-03-2019.dxf
Hi Alex, the most likely cause of this will be if the DXF is using Xref's or external referenced drawings. Please ensure the entirety of the DXF contents are within the file itself.
Shane Regan | Principle Building Performance Support Engineer
Hi Shane,
Thank you for the response.
Unfortunately, this is not the case. There are no XRefs loaded into the file (see below).
Have you got any other ideas with regards to what the problem might be, and how to resolve it?
Hi Alex,
We would need to examine the DXF to be certain - could you please log a Hevacomp Service Request using the Service Request Manager and attach the file in question?
I have done this.
Did you receive it?
Alex
Hi Alex, yes I have picked up the Service Request and I am examining this matter for you. I will email you as soon as I have further details.
