I'm running V26.06.00.06 Part L interface to produce an EPC. The system is not producing an XML file. I have tried the usual fixes, which are not working.
kind regards
Keith
Hello Keith,
Hevacomp will no longer produce XML's as the SBEM version has since been updated.
To run your PartL calculations on the latest version of SBEM, and to produce XML's, OpenBuildings Energy Simulator needs to be used. You can import your Hevacomp project to do so. Please see further information in this regard in the announcement here.
I will log a Service Request for you to provide you with a link to the OpenBuildings Energy Simulator priority build - you should receive an email shortly.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thanks Shane
