My model consists of two floors, 2.7m high for first floor and 2.7m for second floor. I added a pitch roof which messed the whole model up, so i deleted the roof data from the DDBROOF.NDX folder along with the ROOFPOLY.* and RLIGHTPOLY.* files. The model has become slightly better, but in 3D model view i can see straight down to the GF- so the GF has no ceiling. How do i add a ceiling to the GF. I also want to add a pitch roof with the middle edge elevated 2.25m, but i cant seem to get the datum height correct. Please can someone help me. im assuming the datum height is just 2.7+2.7=5.4m.
Hi Shane,
Thanks.
Under room data the height of the room shows as 2.7m as shown below:
But the individual wall and partition heights are not showing as 2.7 but are being extended to the roof. In this case is the room height actually 2.7, with a false ceiling?
If i was to go back to global changes and change the ff room heights back to 2.7 but model shows up like this again, and when i do the roof settings as before the wall heights change change.
Shane, is there a number i can ring to get through to you so that i can get a better understanding of the model data.
Hi Aakil,
Everything appears to be set up fine in that case.
Should you need to there are several ways of getting in touch:
You can log a Service Request here
or, phone us at the number relevant to your country here
or, contact us on this Building Performance forum.
Please note that extensive guidance on entering and setting up roofs can be found in the manuals, eg as below:
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Thankyou very much Shane.
