Ive set up a chilled water circuit and keep getting run time error 5 when i try to calc the system - Any help would be appreciated.
Hi Adam,
This would usually imply that there is invalid data within the project, such as a closed loop or disconnected pipe, I would need to inspect the project to be certain if you could please forward the project folder? Please find upload link here. (note this will expire in 24 hours)
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
Thanks for the reply i have uploaded the file to the link.
Thanks Adam - one thing I can see you uploaded the data files within the project individually - would you mind please zipping the project folder and uploading that instead? Just to make sure nothing is missed. Many thanks, Shane
no problem Shane zip folder should be there now
Thanks Adam, the error is due to invalid figures that have been entered into the floor change connectors highlighted below. The rest of the system is fine.
You will need to use Pipes Group Delete to remove the floor change connectors and associated pipework from each floor they exist on, redraw, and ensure to enter valid floor number and height data - as demonstrated in this example.
