Ive set up a chilled water circuit and keep getting run time error 5 when i try to calc the system - Any help would be appreciated.
Hi Adam, this may be the cause of some issues in that case as all 3 must be present and installed in the correct order.
To install fully you will need to, in this exact order:
1. Download Service pack Update 10 (as seen here)
2. Uninstall Content Pack 3
3. Install Service pack Update 10 (hcomp26060012en_updt10)
4. Install Content Pack 3 (hcomp26060400en_updt3)
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
