Hi there,
I use the Hevacomp V8i SS1 SP2. When I open existing projects the software often opens a new small window says:
.... Microsoft office project professional 2010....
....The features you are trying to use is on a network recourse that is unavailable.. click OK to try again or enter an alternate path to a folder containing the installation package ''PrjProrWW.msi'' in the box below.
I select OK and says the path cannot be found.
Then I select cancel and opens a new windows with an 1706 Error.
Besides this, In one specific project I did, I am trying to open the results in the CIBSE gain and the software crashes. I have built the project and I am afraid of losing the work and waste time doing it again.
Please give me some kind of assistance.
Thanks!
Hello Anastasios,
This is a actually a Windows error rather than one created by Hevacomp - if these projects are saved on a server then as a test please copy one locally to your C drive and try to run it from there, and check if the issue persists.
Also the version you mention is a very old version of the software. I would firstly advise uninstalling all mention of Hevacomp and installing the latest version as detailed here. Please ensure to disable UAC and install each part as full admin.
Shane Regan | Principle Building Performance Support Engineer
That is very strange because I have no such problems
