My company has recently upgraded from Windows 7 to Windows 10. Hevacomp is not producing any reports since the upgrade - even on past projects? I have a simple extension building and just want heat loss load calcs but the results from my model are blank? can you please suggest a fix? thanks
Thanks Shane appreciated - I'll give it a go. My UCA is set to Never Notify is this going to be good enough for the install ? or will I need to disable the UA in the Registry Editor? Its just I have to book time with IT and I want to get it right.
No problem Alan, setting to never notify should be fine, just right click and run as admin and that should hopefully do the trick.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
