Partition Heat Flow, Hevacomp
Hi.
I have a room completely joined and surrounded by other rooms. I have set the temperature of all these rooms to be the same. Yet the central room has a temperature differences across its partition's to the other rooms.
How is this possible?
Many Thanks.
Parents Reply
  • Hi Omar,
    I did indeed, many thanks! Hope you did too. It will be hard to tell for certain without seeing the project files but I expect that the calculation is performing correctly in this case, as the heat Loss calc will take the design temperature figure from either the Winter design temperature shown below, or, from the profile if that is selected.
    Have you selected the same profiles in this room and its surrounding adjoining rooms?
    Shane
    Shane Regan | Principle Building Performance Support Engineer
