Hi Vishal,
I have successfully repaired the project and I will email you shortly from with a link to download the files.
Shane
Shane Regan | Principle Building Performance Support Engineer
Thanks Shane!!
Appreciated and thanks!!!!
Vishal
Hi shane,
I copied the data you shared, and trying to open the project it is showing that path is read only, so copied the data with different location still it is showing read only path, i tried 2,3 location but it is not working out.
Thanks and Regards,
Hello Vishal,
The file sent was a zipped file - did you unzip beforehand?
Please unzip, place the project folder into your Hevacomp Projects folder, and then to open right click on the Hevacomp shortcut and Run As administrator, open Design Database, and select the new folder.
Answer Verified By: vishal jadhav
Thank you shane, it work out and thanks to paul also.
