I'm unable to import the existing design database file into the OpenBuildings Energy Simulator project. From the OBES from end, I select import from the left-hand-side dropdown menu and then exchange file types.
the Hevacomp DDB is not included as a selection option.
Best regards
Keith
Hi Keith,
It sounds like you have started OpenBuildings Designer, rather than OpenBuildings Energy Simulator.
Please find details below:
Starting OpenBuildings Energy Simulator
Shane
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Keith Forster
Thanks Shane,
school boy error!
No worries Keith, you're not the first to stumble on that and you won't be the last! If you need anything else just let us know.
