Heat Loss - Simple v Complex Model
Could someone let me know the main difference between simple and complex model when carrying out a Heat Loss calculation?
I can see complex model does not let you chose between setting the air or resultant temp (fixed on resultant) - but the fabric loss comes out slightly higher in complex model than when selecting resultant temp with a simple model.
