How to draw external doors?
Can someone share a screenshot of how an external door should be drawn in AutoCAD so that it gets picked up by the AutoDefine function in Hevacomp, please? Windows work great but however I draw doors they never get recognised and need be added manually. (I use the appropriate layers). Thank you for your help.
  • Hello Shane,
    Thank you very much for looking into this issue, I really appreciate it. And thank you for the workaround. In a separate message you recommended Openbuildings Designer and Energy Simulator. I have Openbuildings as well, the reason why I stick with hevacomp (for now) is that, honestly, Openbuildings feels a bit clunky and it is very unstable at times (random crashes, freezes, becoming non-responsive, etc) and just setting up a project in it is a separate exercise. At the same time Hevacomp is agile, setting up a project is quick and easy and it does the job quickly and well. So for me it's going to be a slow transition to Openbuildings Slight smile
  • Hi Adam, thanks for the feedback. I would firstly ensure you are on the latest version as it sounds like you may be running on an older install - the latest is currently update 8.
    However I have also searched our records here but cannot see any  issues or queries raised in relation to this from you so if you are struggling I would urge you to get in touch - please log Service Request or post to the Energy Simulator forum and we'd be more than happy to assist.
    For example in relation to creating projects you need to create a new Workset - a video demonstrating this and a guide on each step can be found here.
    Shane Regan | Principle Building Performance Support Engineer
  • Hello Shane,
    Thank you for the thorough response. As I understand OpenBuidlings designer is not a finished product. For example at this stage domestic water system sizes is not as comprehensive as it is in Hevacomp. I understand Hevacomp System Builder is being retired but has it or is it going to lose any of it capabilities or can I still use it as before just not expect any updates or support?
  • Hi Adam,
    As Hevacomp consists of so many individual programs such as Design Database, Netsys, Connect, and System Builder,  the full transition needed to be divided up into separate stages, with Design Database being the first to be developed in OpenBuildings Energy Simulator. Pipe and Duct sizing is scheduled for Update 10 next year. You can continue to use Hevacomp throughout this transition and it remains supported until the capabilities are present in OpenBuildings.
