I've been using Hevacomp Netsys to calculate the ventilation system resistance. However, the results seem a bit high and I don't know why. The entire system is only within one large room and the results show 119 Pa. Velocities do not exceed 3 m/s.
Would you be able to look at that, please?
Thank you,
Pat
Hi Shane, I see, thank you for your help, much appreciated.
