Hi Team,
I wanted to know if it's possible to copy/add a room from Room Data-->Select Room tab (see below). I'm not sure if by doing so, the copied/added room will appear on the plan and on the 3D. Also, I happened to rename a room from Room Data-->Room Data tab but then the room disappeared from both the 2D and 3D plans. Is there any way to fix it?
Many thanks in advance for your reply!
Carlo
Hi Carlo,
Room Data mode and CAD Input mode are not interchangeable - only one should be used. For instance adding a room via Room Data only provides the basic properties of the room and will contain no information in relation to the geometry required by a CAD model. Such rooms will not be found in CAD input.
When entering Room Data you will have seen the below - this step should be treated with caution according to the text highlighted:
To avoid any unintended model inputs I would personally recommend using only CAD Input for future projects. I hope this helps to clarify, if you have any other questions please let us know.
Shane Regan | Principle Building Performance Support Engineer
