Hi
I am having issue with Hevacomp installation/launching on my PC. For your reference below is my PC built. Please could you confirm if the PC is compatible and clarify what could be the issue and suggest a step wise guide to the latest Hevacomp Software installation Including add-ons for report generation.
Many Thanks
GL
Hi, this issue is due to insufficient Windows permissions. I cannot be certain if this has allowed the software install to completely, however could you try right-clicking on the shortcut and selecting Run As Administrator?
Also a secondary issue is that from the image of the Hevacomp shortcut you appear to be installing a very old version - what is the filename of the installer you are trying to install?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Shane Regan
Hi Shane
This has been run as system administrator by my IT helpdesk. However the issue still persists. The version is as below; is this the latest?
Thanks for the details, that appears to just be an old update, not the actual installer. Also I can confirm it is quite old at this stage.
Please find the latest installation detailed in this Wiki.
Good afternoon, I hope the installation went well? If you need any assistance with it please feel free to log a Service Request (here) and we will be happy to assist you directly.
Thank You Shane for you assistance. This has now been resolved.
