Please can you confirm if Hevacomp V8i software is still available to download as it does not appear to be available from the software downloads on the website.
Hi Steve, yes that is correct, it is no longer available on the download site, however should you require the installation files please log a Service Request here and we would be happy to provide you with them.
(Note that if you have previously installed on the machine in question you may actually have the files already - should you need to search for them they are named as below).
hcomp26060000en
hcomp26060012en_updt10
hcomp26060400en_updt3
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Steve Austin
Shane
Can we use the open buildings software for pipe and duct sizing or do still need to use V8i
Steve
Hi Steve,
Yes you can continue to use Netsys, with pipe and duct sizing scheduled for completion in OpenBuildings in update 10. The details at the below announcement should help to clarify:
Hevacomp to OpenBuildings - Transition update - Energy Simulation Forum - OpenBuildings | AECOsim | Speedikon - Bentley Communities
Specifically:
Pipe and Duct sizing will be available in OpenBuildings Designer as part of your OpenBuildings license, and is scheduled for completion in Update 10. This has very similar workflows to Netsys, with single line tracing and connecting to outlets/inlets, and additionally, the ability to promote 3D.Note Duct Sizing is already available in OpenBuildings Designer, with US fittings only at this time. When UK fittings are available and pipe sizing is completed, further training resources will be available to aid transition
Hope that helps.
Regards,Shane
I have logged into the share file log in and accessed the dashboard however the files do not appear to be there.
Files received
