I have connected a series of diffusers to ductwork and when I press size the system I get "error 76, path not found" and the system closes.
Rory
Hi Rory,
Thanks for putting this forward, this is due to an improper installation, please find the guidance here.
Krishnendu
Hi Paul,
Thanks for your prompt response. When I click the hyperlink shown below I get "page not found"
Do you have another solution?
You should be following the installation as described in the link here.
P.S: Follow the sequence as demonstrated and turn down the UAC from your control panel before installing.
I did this but am now receiving the following error.
Any suggestions appreciated.
Thanks for putting this forward. This means there are a few invalid data in your project. I would be happy to take a look, if you please raise a service ticket on our portal from here
