Hi All,
Please can I get help with obtaining Hevacomp installation files.
Already raised a service case, but not getting much luck.
Hi Patrick,
We are uploading the correct files through sharefile, it will be there at your end within a few mins.
Krishnendu
Thanks Krishnendu.
Got the files now.
Could you also explain how we can upgrade it now.
Should we remove the old version first??
Also please advise if we need a new activation key etc.
Hello Patrick,
Thanks, so install the latest you would have to uninstall all the previous remnants of the software and then install the new one. Please follow the installation procedure here. And you should be able to continue with Hevacomp with your existing license
Thank you!
Will give this a go.
