I built my model in Hevacomp but when I try to run CIBSE calc's a prompt shows up "DDB Program Not Available".
Hi Krishnendu,
This seems to be happening for all projects.
I can still modify geometries and rooms but cannot run any calcualtions.
regards
Hi Grant,
Thanks for the details. If this was working previously until recently I imagine it would have been changes external to the software that have caused this - most likely a Windows update that has increased permissions restrictions on your machine.
A quick test is to close Hevacomp, and then start it by right-clicking on the Hevacomp shortcut and selecting Run as Administrator.
If that does not work I would suggest also lowering User Account Control in your Windows settings, and then trying to run as Admin again.
Shane Regan | Principle Building Performance Support Engineer
Answer Verified By: Shane Regan
Hi Shane,
I already have administrative rights in the machine.
I have reduced User Account Control to minimum and run Hevacomp as admin with right click but the same issue is occuring.
Thanks for testing that. It's strange that this should occur only now, as this is usually a result of a particular component not registering during install. I'm nearly certain this isn't a licensing issue but before we explore re-registering components it would also be worth re-entering your activation key if you could please, just to rule it out:License Activation - Hevacomp Wiki - Hevacomp - Bentley Communities
Shane
Hope you had a good weekend! Did you check the licenssing as Shane suggested above? Please let me know.
Krishnendu
