I built my model in Hevacomp but when I try to run CIBSE calc's a prompt shows up "DDB Program Not Available".
Hello Grant/Attir,
This error is usually a result of particular components not being registered on your machine.
Please do as follows:
1. Turn off User Account Control completely - see here
2. Go to C:\Program Files (x86)\Bentley\Hevacomp V8i\Hevacomp, as below, and right clikc on reg.bat and run as admin:
3.Ensuring that UAC is still disabled, right click on the Hevacomp shortcut and Run as Admin to start the software. See if the issue remains.
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Hi Shane,
Unfortunately the issue persists, is there an update to Hevacomp Software by any chance?
Hi Grant,
There are no further updates for Hevacomp as all development is now in OpenBuildings - the DDB calcs can be found there. If you need assistance in getting started on Energy Sim I would recommend following the arrows down through the Energy Wiki here.
Regarding the Hevacomp error; we can try manually registering the component itself. Could you please go to
C:\Windows\SysWOW64
,and check that the following item is present?
GRAPHS32.OCX
