Heating Pipe Sizing in Netsys - Emitter Queries
Its been a while since the last time I used Hevacomp so apologies if the questions seem trivial.
I am trying to model a relatively large project, I have already placed all my emitters (some ceiling void, some floor level).
When I try to connect the emitters using separate flow & return pipework, it appears the emitters may not be connecting. Zooming in shows that the grid doesn’t seem to always line up with the connection point of the emitters, as i’ve modelled some of them at 45 degrees (see figure below) I’ve tried checking this in the isometric view however due to the large building it is quite difficult to check. Is it ok to model the emitters at 45 degrees? And is there a way to check whether they are connected?
My other question is regarding the system marker. Do I need to place it on the flow or return? Or do i need a single flow & return pipe?
Thank you in advance
Seb
