Hi Shane,
I am trying to find the orientation for my design: when i traced the room and i push the 3d view i cannot see the earth level and the sky if i remember well it used to show this orientation in my previous company can you pls tell how to do that?
Kind Regards
Nick Ktorides
Hi Nick,Many thanks for logging the new post, much appreciated. The orientation of your building will be visible in the bottom right of the CAD Input screen via the North Arrow, and can be set as below:
CAD Model Design - How to specify an Angle to South - Hevacomp Wiki - Hevacomp - Bentley Communities
It will also be available in your defaults as below:
I hope this helps to answer your question?
Shane Regan | Principle Building Performance Support EngineerHevacomp to OpenBuildings - A complete guide for every user | Bentley Communities
Answer Verified By: Nektarios (Nek) Ktorides
Sorry for my late reply, sorry my bad perhaps my description was not clear enough, i will try to describe it.
I remember once that when you look your 3d model there is a way that you specify the floor. For example when i design the ground floor there is not something under it so the model is like hanging on the air even i set it up as gf. So i need to set up the ground and the sky if that make sense.
Hi Nick, thanks for the info. I think what you describe was in quite an older version of the software, as the 3D view has looked like this for quite a while now. Or you may be looking for the Simulator Internal sunpaths as below?
