Check for Updates and Wiki viewer in Bentley Hevacomp
NOTE: This article refers to V8i (v25) only
(This functionality is preserved in v26)
With recent updates to our BE|Communities site, it is no longer possible to provide a live "Check for updates" or Wiki viewer from within the Bentley Hevacomp V8i (v25) software.
Software versions
To see if you are currently running the latest software you should check the following version numbers:
  • 25.06.9   should be displayed on the Opening Menu of the software
  • 25.06.15 should be displayed on the Design Database menu
If you are seeing different numbers in these locations then you should update to Service Pack/Update 29.
  • Details on the procedure for downloading and applying the update can be found here
Wiki Articles
If you have been accessing the Bentley Hevacomp/Building Performance WIKI from within the software you should now use the Support Solutions link above or you can access it by clicking  here
Notes and further links
For further information concerning Bentley Hevacomp software and update versioning, please read our News article here
